Trouble Controlling Wall Fill
12 ANTWORTEN 12
Nachricht 1 von 13
PhilvK
713 Aufrufe, 12 Antworten
I want to control the wall fill on some walls. The Generic walls at the orange arrows below are are assigned the Default Wall material which doesn't have anything assigned to that category for cut patterns. The View Specific Elements Graphics for these walls are set to By Material.  The walls are still showing as filled gray in Hidden Line mode. What else could be controlling this please?
12 ANTWORTEN 12
Nachricht 2 von 13
mhiserZFHXS
als Antwort auf: PhilvK
Phasing and phase filters.
Nachricht 3 von 13
PhilvK
als Antwort auf: mhiserZFHXS
The walls are set to New Construction phase. If they're being controlled by Phase Falters, shouldn't they be solid black based on the settings below?
Nachricht 4 von 13
Sounds like conflicting overrides.
It may not always be clear which method of override takes priority over another method, that is, which method "wins" in determining the display of the element. The following list may not cover every scenario, but it includes some common overrides. (1 is the highest priority and 10 is the lowest priority.)
1. Linework Tool
2. Override Graphics in View By Element Halftone
3. Graphic Display Options - Silhouette Edges
4. Override Graphics in View By Element
5. View Filters
6. View Depth - Beyond Line Style
7. Phasing Graphic Overrides
8. Visibility/Graphic Overrides Override Host Layers Cut Line Styles
9. Visibility/Graphic Overrides Projection/Cut Lines
10. Project Object Styles
Help | Element Visibility Override Hierarchy | Autodesk
Nachricht 5 von 13
mhiserZFHXS
Ah, then its your V/G overrides / view template.
Phase overrides are also determined by the phase filter, so you must have a filter applied that doesn't override new materials.
Nachricht 6 von 13
Wall are New Construction but what is the what is the View's Phase Filter set to.  Also, what is the Detail Level of that View? Just contemplating the possibility of a Coarse View Fill/Pattern (under Wall Type Properties).
Nachricht 7 von 13
PhilvK
als Antwort auf: barthbradley
VG settings are blank. Phase Filter set to Show All which says 'By Category' for 'New'.
Thank you guys for your help...I'll keep looking.
Nachricht 8 von 13
Set the View's Phase Filter to Show Complete.
Nachricht 9 von 13
PhilvK
No change under View Complete, or even Show New.
Nachricht 10 von 13
mhiserZFHXS
None of your filters have "New" set to "Overridden". So its not changing any of them.
Nachricht 11 von 13
@PhilvK
Coarse View?  Like I said above, a Wall Type can have a Coarse Scale Fill Pattern/Color.
Nachricht 12 von 13
mhiserZFHXS
@barthbradley
We'll figure it out one of these days :Gesicht_mit_Freudentränen:
Nachricht 13 von 13
PhilvK
These walls display as expected in Coarse View
