Troble with "Cut or Join Geometry Fails" message
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
n.gamsakhurdiya
439 Aufrufe, 1 Antwort
Hello
I shall begin with the issue of "Families". Specifically "Generic model" and "Generic model void".
Below you may find some screenshots.
what exactly happened.
I need create "family" with this 2 objects. After then i need to move it near to other object.But i get some warning.
I need keep this small distance between them. I do not mind about "UNjoin" its.
But Revit want to delete "family" any way.
it's hard to explain. PLS check the screenshots. By parameters my Void moving to that doteBy parameters my Void moving to that dote
and than i get warningand than i get warning
here i added to parameters +0.1mm but still warninghere i added to parameters +0.1mm but still warning
another sample of this type of problemmanother sample of this type of problemm
1 ANTWORT 1
Nachricht 2 von 2
Luiscko
als Antwort auf: n.gamsakhurdiya
Revit has limitation about their geometry if you want to tried this i recomend use at least 0.5 mm o 1 mm distance to the element that you want.
Luis Rodríguez
BIM Structural | GEDCOM
GEDCOM Institute
YouTube |Facebook |Twitter | LinkedIn
