Hi Everyone,
Please refer to the attached image for reference.
New to revit and would appreciate your help.
I made a new in-place stair family.
I am looking to avoid untrimmed regions in stringer profiles of landings and runs. Revit does not seem to like the landing by sketch feature much.
Also, Is it possible to assign different depths to stringer profiles on landings and runs? (not left and right altogether)
Currently its 270mm depth all around but I would like to change only the landing stringers to 370mm depth while maintaining the runs with 270mm stringers.
Cheers
Have you tried unchecking "Same as Run" and then modifying stringer properties at landing?
It helped with top end of run to landing connection but the landing to run connection is still untrimmed.
I would be happy with the unmatched trims if I could change the stringer depths for landings and runs independantly. Any suggestions?
