Trimming and Splitting Masses
A3XXFR
A3XXFR
I am trying to recreate a model I made in rhino with Revit's Massing tools but I'm having trouble doing it. Attached are some images from Rhino and what I've done so far in Revit. The main mass is what I'm after. It's basically a wall slanted at 80 degrees with a sweeping roof. So I made a mass for the wall and the roof.
Initially I thought I could Mass the wall and make it taller than needed. Then use wall by face and then finally use attach top/base to make the wall meet the roof. However, it seems attach top/base isn't available for walls created with wall by face. So that doesn't work.
What I want to try now is to use the roof mass to trim the wall mass that is above the roof. Is this possible? If so how can I achieve it? Or am I going about this in the wrong way? In which case could you point me in the right direction?
Thanks in advance!
Revit 2021, 2022, AutoCAD 2018, Inventor 2021
Specs:
AMD Ryzen 5900X, Nvidia RTX3080, 32GB RAM
Ilic.Andrej
Play with voids.
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
My suggestion would be to get rid of the middle-man and re-create the mass in Revit so you can directly modify it and quickly update to face.
A3XXFR
Guess I'll look into that for my next project. For now I'm sticking with importing the Rhino model bit by bit in to Revit.
Specs:
A3XXFR
Yeah, that was the plan. Gonna look into it for my next project.
Specs:
Please could you re-load the solution?
Kind regards,
David
