trimming a wall to two surfaces on roof
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
rclement
579 Aufrufe, 5 Antworten
i am trying to trim the wall to the roof since there are two surfaces how do you trim to both surfaces at the same time
attached is my model
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: rclement
Attach the top of the wall to each of the roofs.
Nachricht 3 von 6
Ah, the old "Commercial Design Using Autodesk Revit" building.
What walls are you trying to "trim" to roof? From what I see, all your Project walls meet the roof.
Nachricht 4 von 6
rclement
als Antwort auf: barthbradley
i gather you used this before. in revit 1 i  attached wall to bottom of roof but it goes past the roof on a angle into that 4 fr aluminm wall. in revit 2 i trimmed the wall to the front face of the roof  and it goes up not conforming to roof
so basically in either case there is a opening in the wall
Nachricht 5 von 6
Edit the Wall Profile and shape it to fill in that portion.
This?
Edit Profile:
Nachricht 6 von 6
rclement
i thought so but i like to ask just in case there was a way
