I have a question regarding the trim tool. When I select the trim tool, I am only given the option to select one reference as the trim boundary. However, on several occasions, I want to select multiple references as the trim boundary (see the attached image for an example). In the attached image, I want to trim the portion of the line that is within the rectangle, but I want the lower and upper portion of the line outside of the rectangle to remain. How would I go about this? I am sure I am missing something very simple. Thanks for your help!
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
Selecting multiple trim boundaries like Acad is not possible in Revit... Use Split then trim.
