trim MASS FLOOR to MASS WALL
5 ANTWORTEN 5
Nachricht 1 von 6
623 Aufrufe, 5 Antworten
The walls are created using BLEND to resemble ship  but the thickness of floor slab protrudes out of walls because wall are tapered.
How do I trim MASS FLOOR to MASS WALL, pls refer to attached video.
5 ANTWORTEN 5
Nachricht 2 von 6
loboarch
als Antwort auf: Anonymous
No video attached, but it sounds like you need to alter the sketch of the floor and use the pick edge tool to pick the walls to define the floor boundary.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
Nachricht 3 von 6
als Antwort auf: loboarch
Nachricht 4 von 6
You would need to create a void outside of the "boat", or a "negative boat" and use it to shaved to unwanted edges of the floors.
Nachricht 5 von 6
Another thought, make the floor a bit smaller and add a 'wedge' like slab edge.
Nachricht 6 von 6
als Antwort auf: ToanDN
