Hey all. Hopefully a simple question.
I've got a CW leaning out 9.5 degrees but the horizontals are angled so they are parallel to the floor at the 9.5 degree angle. I'm trying to trim the jambs to match. Any suggestions?
Using Revit LT 22
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
Easiest is to
Thanks for your response. That would work if the head were not angled as well. I've shown the head I'm using in both a vertical position and then angled. It makes the bounding box quite large.
Any other thoughts?
Works either ways...it has nothing to do with the profile being slanted or not but more with
...See below GIF and the revised Attached Model
