Hi all,
I was trying to create detail lines in the detail view that is created from an assembly. (right-clicked to create Assembly View.)
However, as titled, some features such as trim, offset, slice and align are disabled when I draw the detail lines.
May I know the reason for this and if it's possible to enable that? Your help is much appreciated. Thanks.
Best regards,
I don't believe Revit supports features under modify panel on Assembly view.
Hi, you can make a group from detailing components like lines etc. and copy to drafting view. It will not solve the problem in 100% because you will not have the assembly in there but you can edit detailing at least.
Is there any reason for this? It just seems random to me. I mean, are assembly detail views any different from regular detail views?
Yes, for some reason they are different from other views what is frustrating because assembly views are the ones that need to be detailed, for example, for manufacturing.
