trees in revit 2016
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
1251 Aufrufe, 5 Antworten
trees in revit 2016
I have just upgraded from 2015 to 2016 & trees have stopped working.  Planting is visible in hidden line, consistent colour & wireframe on projects created in 2015 or earlier.  But not visible on realistic, raytraced or any renderings.
In 2016, any planting is replaced by a small cube, even when the project is created in 2016 from the 2016 library with RPC trees.
Checked all the usual phasing, visibilty /graphic overides, reveal hidden elements etc.
checked the graphics accelerator settings........
hmmm.
5 ANTWORTEN 5
Nachricht 2 von 6
L.Maas
als Antwort auf: Anonymous
Did a quick check Revit 2016 with Service Pack 1. I see the RPC trees from the 2016 library without problems in all views, including rendering.
Louis
Please mention Revit version, especially when uploading Revit files.
Nachricht 3 von 6
als Antwort auf: L.Maas
Hi there
thanks for your help
did the SP1 upgrade and checked the build reference number in About Revit, and SP1 has been correctly applied
Unfortunately still no trees, or people entourage (so anything RPC based)
trees drawn in 2015 have appeared in wireframe and hidden line views only.
trees drawn in 2016 are drawn in all views as small white cubes.
All the above was in the same project.
Jake Loveday
Please consider the environment before printing this email Robert Gordon University is the top university for graduate jobs in the UK (HESA 2013 & 2014) Robert Gordon University, a Scottish charity registered under charity number SC 013781. This e-mail and any attachment is for authorised use by the intended recipient(s) only. It may contain proprietary material, confidential information and/or be subject to legal privilege. It should not be copied, disclosed to, retained or used by, any other party. If you are not an intended recipient then please promptly delete this e-mail and any attachment and all copies and inform the sender. Please note that any views or opinions presented in this email are solely those of the author and do not necessarily represent those of Robert Gordon University. Thank you.
Nachricht 4 von 6
Viveka_CD
Hi explorer @Anonymous
Thanks for posting on our forum!Smiley (fröhlich)
You can configure Revit for Additional RPC Content
Can you check the recommendations HERE and let us know if this resolves your issue.
Also please check your system requirements for your Revit version HERE
What graphics card do you have? Can you confirm if you have the latest updates for the graphics card driver?
Please mark this response as "Accept as Solution" if it answers your question. Kudos gladly accepted.
Nachricht 5 von 6
als Antwort auf: Viveka_CD
@Viveka_CD resurrecting 2 year old posts now are we?  Aren't  you busy enough taking care of the ones in the past few weeks? :zwinkerndes_Gesicht:
Nachricht 6 von 6
Viveka_CD
Ha @Anonymous good catch Lachender Smiley the old ones need some refurbishing too!
