Tread visibility in floor plan / visibilidad de "tread" en planta.
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
344 Aufrufe, 2 Antworten
Hello!
I have a stair with a "special" tread profile (Attached). I can see my tread profile on sections, 3D views, and elevations, but I can not see it in floor plan.
Is there anyway I can see it in floor plan?
Thank you very much.
Hola!
Tengo una escalera con un perfil de "tread" personalizado que no cubre todo el escalón, tan solo una franja del mismo (adjunto). Lo puedo ver en vistas 3D, secciones, elevaciones... pero en planta no lo puedo ver.
¿Hay alguna manera de configuración en la que pueda diferenciar el "tread" de la escalera?
Muchas gracias de antemano.
Saludos,
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: Anonymous
Stair is a "special" category (as in Special Olympic) that does not show a true projection on the plan view.  You will have to fake them in with detail lines or filled regions.
As a workaround, you could create a railing type with special balusters to present the pads on top of the treads and attach it to the stair.  That will show on plan view.
Nachricht 3 von 3
als Antwort auf: ToanDN
Thank you very much dear ToanDN, you just made my day!
Really creative way for achieve this solution. It works perfect.
Again, thank you very much.
Tags (1)
