I believe to have discovered a bug.
After using the "Split Segment" tool to make a jump the a section line, we lose the Tread Numbers to some (but weirdly not all) of our stairs.
Please see below.
Stair section, straight, showing tread numbers:
Stair section, split, tread numbers now invisible, but the invisble, dotted line belonging to the Tread Numbers tool is still selectable:
Has anyone come across this before? Does anyone have a solution?
Many thanks,
M
I'm not able to replicate. I tested on 2020. Which version are you on? Can you post your file?
On Version 2020.
Unfortunately I can't share models due to confidentiality reasons.
Can you post screenshots showing that a split-segment Section shows tread numbers in a linked file? I tested multiple times and found the bug during each test.
