Trapezoidal strip footing
11 ANTWORTEN 11
GELÖST
Nachricht 1 von 12
4273 Aufrufe, 11 Antworten
I have to draw several strip footings with trapezoidal cross sections. What would be the easiest way to achieve this?
Regards!
11 ANTWORTEN 11
Nachricht 2 von 12
als Antwort auf: Anonymous
...actually, I mislead you. Sorry. But, you do need a profile of the shape you need. Then you can use it in an in-place sweep.
Nachricht 3 von 12
Use in-place sweep, pick 3d edge of the bottom of the wall for path with a predefined profile.
Nachricht 4 von 12
als Antwort auf: ToanDN
Thanks for your suggestion!
Will I be able to add rebar to this kind of element?
Nachricht 5 von 12
Yes.
...categorize the in-place component under "Structural Foundations".
Nachricht 6 von 12
als Antwort auf: barthbradley
OK! Thanks!
How do I start? From "create generic model" family,.....?
Nachricht 7 von 12
Open the existing Profile Family for "Slab Edge Thickened" and do a Save-As, naming it what you want. Modify it as necessary to make your trapezoidal cross-section shape. Save and load into your project. In 3D view, start an in-place component and choose Structural Foundations for it's category and name it. Then use the Sweep tool with Pick Lines to sketch the path by selecting the bottom edge of the wall. Close out of path sketch mode and select your Profile in the drop-down box. Adjust positioning as necessary and then close out of in-place editing completely. Voila! A strip footing appears! Select it to reveal Rebar tool on the contextual tab.
Nachricht 8 von 12
Hi barthbradley,
I'm struggling with your explanations but the only thing I managed to do is
a "save as" part in Profile family and now I'm a little bit lost.
Could you just upload a trapezoidal footing if it's not to much time
consuming? Than I could modify it!
Thanks!
Nachricht 9 von 12
It's not that it's too much trouble, it's  that I have no idea what size and shape you need. It's only a 2D profile, similar to OOTB "Slab Edge - Thickened" Profile. The modeling part is done in the project itself using the "In-Place Component" tool on the "Architectural" tab (under "Component" on the "Build" ribbon). Have you ever modeled a sweep extrusion? That's where you're going to use your Profile to define the cross-sectional size and shape of the sweep (e.g. your strip footing).
...did your mother ever give you one of these as a kid? Same concept. Smiley (zwinkernd)
Nachricht 10 von 12
See screencast.  I have included the steps to create the footing using a sketch-in-place profile and also using a profile family.  The profile family can be made parametric if you need to cover several sizes of the same shape, or simply create different profile families.
Nachricht 11 von 12
Thank you so much!
The only thing I'm missing is "material menu". It's simply not there in my Revit.
Nachricht 12 von 12
Only available when you edit the in place model.
