transparent wall and floor
7 ANTWORTEN 7
GELÖST
Nachricht 1 von 8
17489 Aufrufe, 7 Antworten
I'm so disappointed!!!!!! I have no idea why, but some walls and floors are transparents in a 3D view realistic mode.
I try a lot of things and nothing works. I have tried disable the accelerator, download the beta nvidia drive and nothing works!!
7 ANTWORTEN 7
Nachricht 2 von 8
L.Maas
als Antwort auf: Anonymous
Can be so many things. It can be the materials applied, can be graphics overrides, filters, object styles.
Maybe you can upload that part of your project so we can have a look to see what is going on.
Louis
Please mention Revit version, especially when uploading Revit files.
Nachricht 3 von 8
als Antwort auf: L.Maas
Hey, Attached my file here, I don't have a lot of things, but the most of walls are transparent... If you can take a look here we go.
Thank you
Nachricht 4 von 8
RDAOU
Hello @Anonymous
In the Properties Palette > Scroll down to the bottom
  1. Set the "Phase: Completion"
  2. Set Phase Filter: Show All or Show Complete... you should see all unless settings for those filter has been overriden
Depending on the Phase you select in the Properties Palette for the view you are looking at and the Phase Filter you associate with that ... some elements (depending on the phase and the Phase Filter Settings) will be invisible or displayed transparent/halftone...etc
  1. Go to Manage > Phasing > Phases
  2. Check the Phase Filters for the different Phases
  3. If Show All is overriden...Either check the overrides or set it to By Category
If the above helps, Please mark this reply Accept as Solution...KUDOS are also welcomed (Only if the above helps)
Nachricht 5 von 8
als Antwort auf: RDAOU
THANK YOU SOO MUCH!!!!!! It's everything working now!!! Smiley (überglücklich)
THANK YOU!!!THANK YOU!!!!
Nachricht 6 von 8
RDAOU
You are more than welcome :leicht_lächelndes_Gesicht:
Nachricht 7 von 8
mschirmer
It is nice to see when others have the same problem and a solution is already been done.  Thanks!
Nachricht 8 von 8
I was having the same problem, this fixed the transparency in the model view, however, it made it disappear completely from the plan view. any idea why this would happen? i didn't change anything but the phase completion
