I'm look for a way to visualize interiors where you can see through certain walls or ceilings (mostly outside walls) but (sun-) light is blocked and bounce back. If I cut the model with a section or scope box the room is lit as if all sunlight comes from the cut areas (which is not realistic).
I tried to create a 100% transparent but 0% translucent material but this does not work as expected (I only want to see the light coming through the windows and glass door and in the rendering the light bouncing from the "invisible" outside wall.
Placing a camera inside the room gives an undesired perspective distortion. Does anybody has an idea how to do this? (I have the same problem creating birds eye perspectives with correct shadows and illumination when the roof/ceiling is cut away)
Thank you for any suggestions.
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
In rendered views or Realistic View display?
For the latter (Realistic Views), you can select the wall >> override element >> set transparency to 100... that will keep blocking sun and allowing only what goes through the windows...See below same camera duplicated ( both with identical sun settings:
You can create a view Filter for all external walls and override surface transparency to 100% then apply that filter to all 3D views where you need that effect
For rendering...not sure how one can manipulate the material to make it transparent yet allows absolutely no light through. But again I am not the best at rendering in revit
Thank you for the quick answer! Realistic mode + Transparency override does what I want to achieve and nicely by view so I don't have to change materials global:
Door and Window cast shadows.
But A) realistic is not my favorite view B) build in tender engine ignores the override C) enscape (my favorite engine) also ignores the transparency set by view
Try Painting the surfaces of the Walls (Exterior+Interior) with Glass Material. I think you might like the Rendering result.
My Problem ist that if I choose a glass material I don't get realistic lighting and shadow inside the room. More obvious in a bid's eye view where I don't like the look like after a hurricane (ripped of roof).
Without daylight it's better but I again loose all the light normally bouncing off opaque walls or ceilings when I just take a transparent material.
