Anyone could help me! I have my roof very clear as a glass, on my model, how can I change a transparency, and have a roof shingle showing in my model?
George
Gelöst! Gehe zur Lösung
Gelöst von Assis.Haubert. Gehe zur Lösung
In your material editor, check the graphic transparency and appearance transparency.
Also check the Roof Transparency i the visibility and graphic window.
If you find my post is interesting, I will Appreciate it if you give a Kudo.
If it solves your problem, please click Accept Solution.
George
Hi @jorgedacunha60,
What was the "type" of "roof family" you chose when you create your roof?
If you don't know, click in the roof and tell us what is the type showed in the "Properties."
If your roof is "Sloped Glazing" (your description makes me think that this is the type of roof that is "selected"), try to select (pick) another one.
The types shown may be different than my image, this will depend on which template was used to create the project file.
I hope this information can help you.
Cheers.
Cabe lembrar que caso a resposta ajude, ou mesmo solucione a questão, se possível marque o LIKE/GOSTEI nas respostas, caso tenha resolvido/solucionado, marque como "Solução". Obrigado.
Please note that, if the answer helps, or solves the question, please mark the LIKE in the answers, if you have solved/solved it, mark it as "Solution". Thank you.
- Utilize a ferramenta de pesquisa do fórum, a sua dúvida já pode ter sido respondida;
- Use the forum search tool, your question may have already been answered;
- Marque "Aceitar como Solução", caso tenha resolvido o problema. Isto ajudará outros usuários a encontrar uma resposta;
- Select "Accept as Solution" if it has solved the problem. This will help other users to find an answer;
- E clique em "Curtir" se a resposta ajudou.
- And click on "Like" if the answer helped.
Assis Haubert
CAD/BIM Consultant | AEC Technical Specialist | Colaborador CAD/AEC da
Autodesk Community - Português - Cadklein.com | Facebook | Twitter | LinkedIn
Autodesk Expert Elite Alumni
