Transparency Issues
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
1020 Aufrufe, 4 Antworten
Transparency Issues
I'm working with Revit 2019 and I have come across some form of graphics issue (either this or a setting I have never come across before).
As you can see in the attached snip, joins in walls/windows and other elements are visible through other elements.
I have checked transparency settings and visual graphics and overrides and none seem to be causing this issue.
Any feedback would be much appreciated.
4 ANTWORTEN 4
Nachricht 2 von 5
Erense
als Antwort auf: Anonymous
Can you provide us (a part of) the model to check what is going on?
Only thing i can think of is that the joining of the walls is 'disallowed'
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Edwin Rense
Cadac Group AEC BV
Supporting Consultant AEC
Cadac Group .
Nachricht 3 von 5
L.Maas
Could be a graphics card issue.
-Switch of hardware acceleration in Revit (under Options)
-Try other graphics card drivers.
-Look for other updates (Revit, OS)
-Check on a different computer
-Does it do the same in other (new) views of the project?
-Does it do the same in other (new) projects?
Louis
Please mention Revit version, especially when uploading Revit files.
Nachricht 4 von 5
Delete the view and create a new 3d view see if what happens.
Nachricht 5 von 5
als Antwort auf: ToanDN
Folks,
I feel like quite the dunce .
Deleting all the 3D views and creating new has sorted it.
Thanks a million for all your feedback!
