Transferring parameter data between family instances
4 ANTWORTEN 4
Nachricht 1 von 5
deepesh_wig
437 Aufrufe, 4 Antworten
I want to send the result of a calculated shared parameter from one family to a parameter in another family. Is this possible?
e.g.:
Family 1: a "required refrigeration" value based on the length, breadth, height of the family.
Family 2: a refrigeration plant family which takes the value referred above.
I assume this is possible using systems but I'm not at all familiar with those.
Thanks in advance.
4 ANTWORTEN 4
Nachricht 2 von 5
denis_borodin
als Antwort auf: deepesh_wig
I don't clear understand what is your 1st family, but you can easy make it with primitive Dynamo code
Denis Borodin, BIM Manager. LinkedIn
Nachricht 3 von 5
Mikhail.Davtyan
Can you be more specific? Are this families connectected?
In any way, try ModPlus - there tones of free plugins, one of them is "copy parameter values" https://modplus.org/en/revitplugins/mprcopyparametervalues
It says it cost somthing, but I can use it in free version too
Nachricht 4 von 5
deepesh_wig
Thanks @denis_borodin and @Mikhail.Davtyan for the proposed solutions. Not quite what I'm trying to do. Let me explain a bit further below:
Family 1 is a cold-room element with embedded formulas using room surface area to calculate required refrigeration.
Family 2 is cold-room plant with several family types based on refrigeration generation capabilities.
A typical project may have 3-4 cold rooms and therefore 3-4 plant.
I want to be able to link room 1 to unit 1, room 2 to unit 2, etc. and if room 1 needs 100, unit 1 becomes family type 1. If I change the room size so that room 1 needs 150, unit 1 should automatically change to family type 2.
Effectively, I'm not copying parameters - I'm trying to use a parameter from family 1 to drive a parameter in family 2 in a project environment.
Nachricht 5 von 5
denis_borodin
Really nice question). I think you can use only equipment family and nothing else. Make a property "required refrigeration" into them, calculate it by Dynamo,
and then your family type may be selected automatically
