Transferred Color Schemes
10 REPLIES 10
Message 1 of 11
76jsa
859 Views, 10 Replies
I am using my own Color Schemes with Shared Parameter.
When I transfer this Scheme to existing project and set this Scheme to a template, its not showing any colour fills.
Yes - I have them turned on in Model Overrides.
Tanks for help
10 REPLIES 10
Message 2 of 11
in reply to: 76jsa
Silly question, but I got to ask: Do you have any Rooms/Spaces (or whatever the Color Scheme is for) defined in the Project?
Message 3 of 11
76jsa
in reply to: barthbradley
Yes,
I have the previously used ones and now the transfered ones.
Message 4 of 11
76jsa
in reply to: 76jsa
The color fill works only with the old Color Schemes, not with the imported ones.
Message 5 of 11
in reply to: 76jsa
What Version of Revit?
Message 6 of 11
76jsa
2020.1
Message 7 of 11
in reply to: 76jsa
Well, based on my testing just now in 2020, I can confirm that Room Color Schemes based on a Shared Parameter transfer the Color/Patterns of those Schemes to another Project.  Shared Parameter was even applied to Rooms.  Pretty impressive.
Message 8 of 11
in reply to: 76jsa
As a test, create a new unedited floor plan in the destination file and apply the color scheme see if the colors show.
Message 9 of 11
76jsa
in reply to: ToanDN
NO, it still does not show color fills.
There is some problem with the import.
I have created them to the template file, to have them there from beginning, but that does not solve the issue.
Message 10 of 11
in reply to: 76jsa
Not working still? Strange. Can you walk us through what you are doing step-by-step?
Message 11 of 11
76jsa
In one project I have created Shared parameter (I wanted to have this parameter value in area tag).
Then I have created Color Scheme based on this parameter  - worked perfectly in current project.
Then I executed Transfer Project Standrds (this Color Scheme) to the other project - everything worked - except of a color fill.
I think - it was because I needed to load the Shared Parameter first - then Transfer the Color Schemes.
