Hi All,
We recently created a new project template in Revit 2024. I am trying to put it in an existing project also in Revit 2024. I have used the transfer project standards, checked that the browser organization is checked, but when the transfer is complete, the old project browser remains the same. Both projects are open when transferring. Also, the file location has been changed to the new project template. Is there a way to fix this? Thanks!
Gelöst! Gehe zur Lösung
Gelöst von juliar123. Gehe zur Lösung
Right click on Views in the Project Browser, then select Browser Organisation and chose the scheme you want. The same for Schedules and Sheets.
Done that. The browser is still not updating to the new project template layout and sheet numbers.
Sheets are not included when you transfer project standards. System Types, settings, and view templates are included. For the Project Browser, the settings with not auto apply. You have to set them.
This is how you transfer sheets:
