I am getting an import failed message when I try to transfer my revit file into sketchup. Here is what I have done.
From 3d view/file/export/options/export setup dwg/choose solid/ACIS solid
then file/export/cad format/dwg/next and then ok to save
then open sketchup/file/import/selected the dwg file/then import.
I then get a message that says import failed.
help!
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
That worked - thank you! Is this a glitch in 2018 revit that we expect will be updated? Just curious - the workaround worked for now!
