Transfer DWG to Revit - Disappearance after scaling
1 ANTWORT 1
Nachricht 1 von 2
sahba_ghanbari
187 Aufrufe, 1 Antwort
Hi there,
I transferred a DWG file containing a city plan to Revit, but it seemed to be at the wrong scale. I verified the size and scale in AutoCAD and Nearmap, and everything appeared to be correct there. However, when I transferred it to Revit, it appeared too small. Furthermore, when I attempted to scale it up, the entire model disappeared.
Could you please assist me in identifying what I might be overlooking in the process of transferring and scaling a DWG file in Revit?
Thank you.
1 ANTWORT 1
Nachricht 2 von 2
syman2000
als Antwort auf: sahba_ghanbari
In AutoCAD, measure one of the lines and check the unit. When I measure, it seems to set as meters but the insert unit is millimeters. Change the AutoCAD units to Meters.
Once you set the DWG to meters, your Revit should pick up the correct scale.
