traditional plan...
traditional plan...
Yien_Chao
Advisor Advisor
Message 1 of 13
traditional plan...
Yien_Chao
In many architectural offices in Quebec, Canada (I did not compare with elsewhere in the world) the choice of hatching is only sparingly and to get a better reading of the plan. I will not discuss standards here, but only a fairly simple wish: To be able to display partition walls with only 2 lines and when there are supports such as concrete or concrete block, to display separate hatches and lines.
An example here, but I had to model 2 separate walls. One for the support (concrete block) and the other for all the rest of the finish.
Is it possible to achieve this with just one element while staying at a low level of detail?
Replies (12)
Message 2 of 13
What about Parts and then merge Layers together (after making them the same Material of course)?
Message 3 of 13
syman2000
Part would probably the approach. However if you don't want to merge multiple layers, other method you can use it add profile to the wall.
First add no hatch material to the course
Define the thickness of the CMU wall. Add your sweep profile. There add material to your sweep. Once you achieve this, you should be able to see your profile overlapping with your wall.
In the profile family, this is where you adjust the height and thickness.
Message 4 of 13
RDAOU
@Yien_Chao
What you have done (2x wall Types joined) is the right and quickest to do it...any other way would be unnecessary tediousness.
Message 5 of 13
XXalessio.amodioXX
Usually I model separetely Structural/Architectural and Finish walls. I think is the best practice
Message 6 of 13
Yien_Chao
That would work only if you dont have too many walls and the design is fixed.
Message 7 of 13
Yien_Chao
Will test this one
Message 8 of 13
Yien_Chao
Yes indeed. But both are supposed to be one component. Easier for tagging and quantity check.
Message 9 of 13
RDAOU
@Yien_Chao
Not necessarily...technically speaking they can be 2 components.You can join geometry and/or you can assemble them together (Select both and create assembly).
  • In terms of quantities and take offs, it is the same...both fall under the category walls.
  • In terms of tagging, it is even more convenient because you would be able to tag a whole lot more than material
  • In terms of practicality ... you would be able to issue framing layouts without any extra hassle
The only extra effort which you might need to put is in the Inserts families...door frame would require a slight adjustment to neck both walls
Message 10 of 13
Yien_Chao
will check this one too.
Message 11 of 13
Yien_Chao
i think if you attach both, openings and doors will follow as one.
Message 12 of 13
RDAOU
The opening yes, it will cut both joined walls but the geometry will not behave that way...ie: the depth of the sweep/extrusion of a door Frame will not increase to neck/flush both walls (it will stick to its primary host)...but with a little tweak that can be modified to make it work
Message 13 of 13
Yien_Chao
think i will stick with the first idea : model 2 elements, joined them. less workaround.
Thank all
