toposurface volume
6 ANTWORTEN 6
Nachricht 1 von 7
76jsa
429 Aufrufe, 6 Antworten
toposurface volume
maybe just a basic question.
I have created toposurface with various heights.
But  want to have it just with f.e. 4m ground/volume, not just a shaped plane.
Is it possible?
6 ANTWORTEN 6
Nachricht 2 von 7
Avaris.
als Antwort auf: 76jsa
Yes, expand your toposurface and use a sectionbox in the 3D-view. You need to cut your toposurface to see the depth of your poche. To change material and depth, click the little arrow below 'Building Pad'.
Nachricht 3 von 7
76jsa
als Antwort auf: Avaris.
I have that, but it does not solve my problem, because section box cuts it only as a straight line...
If I use this 3d view i looks ridiculous, because it's cut only somewher.
Thanks anyway :leicht_lächelndes_Gesicht:
Nachricht 4 von 7
Avaris.
Yes, that is the reason you have to expand your toposurface, so the sectionbox will cut also the other parts.
Nachricht 5 von 7
Split the Surface and hide the portion intersecting the Section Box.
Nachricht 6 von 7
Make sure the section box is smaller than the boundary of the topography.
Nachricht 7 von 7
Viveka_CD
Hi @76jsa
Did the recommendations by the experts help with your issue?
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions.
Thank you!
