I'm looking for some Best Practice suggestions, tips, tricks, etc for updating Toposurfaces.
I'll give you a rundown on what I've done;
- Created a surface in Civil 3D.
- Extracted just the contours to a separate *.dwg file.
- Inserted the *.dwg file into Revit using the Link CAD command.
- Moved and rotated the linked contours as required to get them positioned correctly in Revit.
- Generated the Toposurface by selecting the CAD link using Modify\Edit Surface - Create from Import - Select Import Instance.
Everything works as it should and the resultant Toposurface was as expected.
I had to update the surface. I used Civil 3D to do so, so that I would be sure to get the proper results. Once updated, I extracted the contours and updated the same separate *.dwg file that is linked into my Revit model.
I was hoping that since the Toposurface in Revit is based on the linked *.dwg file, the Toposurface would updated because the contours in the linked file were updated. This of course didn't happen.
To get the updated Toposurface, I went through the steps again of linking the *dwg file and generating the Toposurface. Ended up with 2 surfaces, so I just deleted the old one.
It worked, but somehow this doesn't seem like the correct procedure to me. Is there something I missed to get the Toposurface to update based on updated linked file?
Any comments, suggestions, tips, tricks, best practice procedures would be greatly appreciated.
Richard
