How I can measure the distance (height) between two points of toposurface?
Normally I have a point in elevation 615m and an other in 616m.
In my project in Revit I use cm. So I give the elevation 61500 and 61600. I want to be sure that the distance between thse two points is 1m. How I can see that?
Thank you in advance!
Gelöst! Gehe zur Lösung
Gelöst von MostafaElashmawy. Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
make a section passing through them and draw two levels , one at each elevation.
you will find the points passing through them.
Mostafa Elashmawy
Hi @mairh_tsek
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions. - Thank you.
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
