Toposurface not printing
2 ANTWORTEN 2
Nachricht 1 von 3
kjskoog
464 Aufrufe, 2 Antworten
Using Toposurface to create grade lines in elevation view. They show in elevation view and in sheet view but do not print. What could cause this?
Thank you
Kory Skoog
CAD/BIM Manager
Kory Skoog
PM/BIM Manager
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: kjskoog
Hi Kory,
Do you mean when you print, it doesn't show in the print preview and it's blank when printed?
Try checking this out:
https://www.revitforum.org/tutorials-tips-tricks/441-cant-see-view-heres-33-reasons-maybe-why.html
Thanks.
Nachricht 3 von 3
kjskoog
als Antwort auf: Anonymous
Found the issue. The toposurface is beyond the elevation cut but if I move the elevation cut line to include the toposurface I can print the grade but everything below grade does not show. We dash everything below grade to show the footings and foundation in elevation. What I am still trying to figure out is if I can see and print the building without cutting through it, why can't I do the same with a toposurface? Or is there a different way to show a grade line in elevation view?
Thank you for the list. It is a good guide to follow.
Kory Skoog
CAD/BIM Manager
Kory Skoog
PM/BIM Manager
