some contour lines are different only at elevation (vertical land) in the cad file. When I import to revit the contour lines (the ones that shaped the vertical land) are transformed in a slope (no more vertical). Is there any way to revit draw the same information given by cad drawing ?
thanks, Fernando
Hi @Anonymous.
If i understand your post correctly, make sure that all the autocad lines are joined into one polyline and that there is an elevation for each line. When done properly, and brought into revit you can pretty much create your toposurface from the imported file or the alternative is to import the file and place points manually.
Let me know if this is a solution to your query.
Kind Regards,
Andre
