Toposurface from cad survey
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
352 Aufrufe, 2 Antworten
I'm trying to create toposurface  I have survey dwg with z values.
My question is at which level survey dwgs has to brought in to get correct toposurface levels measured from datum
is the datum level is correct level to bring survey in ??
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: Anonymous
just insert it into a 3D view. It'll land where it lands.
...after you create your Toposurface from it, move the toposurface -- not the building.  Understand?
Nachricht 3 von 3
put a marker on the +0.00 on your cad. link it to your revit. move your cad to where your +0.00 on revit is. then create your topo.
