Toposurface Boundary Point to be converted to Interior Point
Ilic.Andrej
Advisor Advisor
Ilic.Andrej
There is this thing that drives me nuts. You know that thing?
When I creating a new toposurface, I am allowed to copy "Boundary Point" outside the surface, automaticly changing the original point to "Interior Point". But, when I wanna do the same thing to a surface that was previously splited using "Split Surface" tool, I get this message:
"A Point is outside of the Surface boundary. Insert the Point on the boundary instead, and then drag it to the desired location."
I don't have time to do this. I just need to copy all the boundary points and offset them by 10 cm. Is there any way to defeat Patrick? 🙂
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
RDAOU
instead of copying and pasting outside boundary, why not reverse it...select all and drag them to the outside (and if it is a must copy after dragging and paste inside)
