Toposurface and Lines on Elevation
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
jorgedacunha60
514 Aufrufe, 4 Antworten
Toposurface!
I have problem on my Toposurface, it shows below grade and I don't know how to solve this problem.
I Also have been tried eliminate some lines on my elevations without success.
Could someone help me to solve these problems.
Much Appreciated,
George
4 ANTWORTEN 4
Nachricht 2 von 5
alan_eu
als Antwort auf: jorgedacunha60
Hi @jorgedacunha60
Probably your problem ll be easy to solve:
1. Did you try to join them? ( Menu modify / join / select that elements)
2. Try to align them. Go in 3D mode and zoom it. use AL command, click in the 1st wall, them the 2nd;
3. Maybe that's a video card bu. Try to disable on options/hardware/use hardware acceleration and restart your revit.
Alan Araújo EESignature
Bee1ColabInstagram Alan Araújo RevitBee1ColabGrupo Whatsapp
Usuários do Autodesk Community:
  • Se a resposta resolveu o seu problema, clique em Aceitar como Solução! isso ajuda os outros usuários a encontrar rapidamente uma resposta e Curta se gostou :leicht_lächelndes_Gesicht:
  • Manda um alô nas minhas redes sociais com +600 vídeos de de Revit/BIM, Templates e conteúdos semanais! Gratuitos! :leicht_lächelndes_Gesicht:
Nachricht 3 von 5
turn on section box and stretch it inward to cut the topo.
Nachricht 4 von 5
syman2000
Looks like your topo is very close to the building. You may want to extend out topo beyond building. Afterward follow what @ToanDN said with the scopebox.
Nachricht 5 von 5
jorgedacunha60
als Antwort auf: syman2000
Happy New Year! Thank you for your input. If I check in the section box,
afterward I have to hide in view in order to render the image, because if I
uncheck the section box, I would have the same problem! I am going to try
your post and I will try to render it.
George
