Hi Autodesk Team!
We are very worried and disappointed with using toposolids in Revit 2025. Despite numerous improvements in the workflow, we see that only around 500 control points are considered in the toposolids. That reduced number of points modifies the input topography and makes the topography very unrealistic. And that is trouble! We need that the toposolids can handle far more control points, like the toposurface did. On large sites we previously had 50 000 points.
Split the large topography into smaller segments, each with its own toposolid. This can help manage the control points within each segment and maintain a higher level of detail across the entire site.
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | Especialista BIM
Autodesk Certified Professional
It turns out that only the creation (and migration from toposurface) is limited to 500 points, but possible to edit/recreate with a large ammounts of points after.
