Toposolids: imprinting a hole/void
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
Haider_of_Sweden
243 Aufrufe, 2 Antworten
I want to confirm if the following is possible.
Ideally, when you create a hole in your topography, it remains permanently in place.
In Toposolids, I create holes using, for example, voids. However, if I move the toposurface for any reason, the hole stays fixed in 3D space.
Is there a way to "imprint" the hole/void directly onto the topography itself?
2 ANTWORTEN 2
Nachricht 2 von 3
ridantuo
als Antwort auf: Haider_of_Sweden
Dimension constraint works for it.
PICNIC: Problem In Chair Not In Computer.
Around 90% of issues can be explained by human error instead of an actual error.
Nachricht 3 von 3
Thank you for a good suggestion.
Accepted it as a "solution", while not the solution one would like to see.
There are lots of things to wish from Toposolids..
