Hello
I've tested toposolids on a couple of projects now a they are all complaining about the accuracy of the toposolid. In this example I created a toposolid from a dwg. As you can see there are a lot of inaccurace here. Is there a way to solve this? And why does it happen? This wasn't the case with topo surfaces.
Gelöst! Gehe zur Lösung
Gelöst von vitorbortoncello. Gehe zur Lösung
Hello
The problem is that it simplifies the terrain so pieces of the terrain are missing. The grey lines in the picture are dwg lines. This is parts of the terrain that are left out.
This is a current issue, and I hope Autodesk comes up with a solution soon:
Only around 500 control points are considered in the toposolids. That reduced number of points modifies the input topography and makes the topography very unrealistic. With Toposurfaces we previously had 50,000 points.
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | Especialista BIM
Autodesk Certified Professional
Yes, that makes sense. I really hope they resolve this soon. Thank you for your help!
