Toposolid unwanted lines in cross sections
4 REPLIES 4
tsdrafting
201 Views, 4 Replies
I am sure there is an easy fix - but I have only been using Revit for 1.5 years - and am still learning.
Whenever I create  cross sections - I always have these vertical lines underneath the footings.  I know it is the toposolid thickness - and after I create cross sections, I take the vertical line distance, subtract it from the toposolid thickness - and it helps - but the lines are still there.
The attached jpgs illustrate what I am talking about.  I also am sending a screen shot of my visibility graphic settings as well as the Object Style Settings.  I am sure it is a quick click or two - but I have played around with these settings - and can't get rid of those vertical lines.  When I click on the lines to make them ""invisible" - they always seem to find their way back on my blueprints.
Any suggestions?  Thanks in advance.
Labels (3)
4 REPLIES 4
azad.Nanva
in reply to: tsdrafting
Which lines do you mean?can you show them ?
for example:
tsdrafting
in reply to: azad.Nanva
I just updated the "Vertical lines under footings" file - red arrows point to my issue (although you pointed to them as well in your example).
tsdrafting
I should also mention - the "perimeter" around the building - that is the perimeter "drop down" lines at every corner. For example - if I have a basement window and wrap the toposolid around the window well - I have the corners of window wells/toposolid corners "drop down" to create the lines I do not want. I am using Revit 2025.
azad.Nanva
oh this is pile foundation,i think, you should filter them in your view.
