Toposolid schedule separate cut and fills
10 ANTWORTEN 10
Nachricht 1 von 11
dominic
654 Aufrufe, 10 Antworten
I am trying to schedule separate cut and fills in a topsolid. Is there any way to schedule cut and fill and area for each cut, and then the total?
I am using in place void for the cuts.schedulescheduleToposolidToposolid
10 ANTWORTEN 10
Nachricht 2 von 11
Alfredo_Medina
als Antwort auf: dominic
What do you mean by separate cut and fill for each cut, if both changes are cuts?
Nachricht 3 von 11
dominic
als Antwort auf: Alfredo_Medina
I wanted to create a schedule which lists each cut/fill as a separate line item which can be identified by its name i.e.:
NAME               CUT       FILL       AREA
Cut 1                5.0m3    0.0m3   7.0m2
Cut 2                10.0m3   0.0m3   9.0m2
TOTAL               15.0m3   0.0m3   16.0m2
We used to be able to schedule pads as separate items with topography.
Nachricht 4 von 11
dominic
And also listing the area for each separate cut. In NZ we use the areas of the cut as well as the volume for Resource consent (planning) drawings.
Nachricht 5 von 11
Join the geometries together. Join geometry removes volume at the union.
Nachricht 6 von 11
dominic
als Antwort auf: barthbradley
I wanted each in place void (which cuts the topsolid) to be itemized separately in the schedule.
as per:
NAME               CUT       FILL       AREA
Nachricht 7 von 11
as per:
NAME               CUT       FILL       AREA
Okay, so filter the schedule to show only the data you want it to show. No biggie.
Nachricht 8 von 11
dominic
I might be missing something pretty basic, but I have attached a RVT file to illustrate the issue. Also when I pick the void cut in the toposolid it doesn't register the cut and fill, although the parameters are present in the type
Nachricht 9 von 11
Alfredo_Medina
To obtain what you need, don't use model in-place, but toposolids. Create a toposolid by sketch, for example, as a rectangle. Revit will show a message saying that toposolids are overlapping. Then, in section view, locate the toposolid where it needs to be. Then do Modify > Cut geometry > select the main land > select the small toposolid.
Now check the schedule. Each toposolid will show data.
Nachricht 10 von 11
Is this what you are after?
Nachricht 11 von 11
Here...just check it out. I think it's self-explanatory.
