Toposolid ridge lines missing in elevations
Anonymous238
Anonymous238
In elevations when the contour of a toposolid has a ridge in it, there is no line representing that ridge. Is there any solution?
Not clear what you are asking. Sounds like you want a cut line thickness - but not for a line that is at the cut plane. For a projection line that is beyond the cut plane.   Is that about the size of it?
Set View Far Clipping to "No Clip".
blank...
Is this what you're talking about? If yes, it's a bug, still not fixed.
https://forums.autodesk.com/t5/revit-architecture-forum/toposolid-shown-only-where-it-is-cut-the-res...
Anonymous238
Yea it looks like that bug. To explain it more - when you are in a view facing perpendicular to a ridge of a toposolid, the ridge peak has no visible outline. So that view begins on one side of the valley and further in the view is the ridge and even further is the other side of the valley, which you don't see as the ridge is blocking it. You won't see that ridge line. You do however see outlines of the toposolid at its boundaries.
