Toposolid question
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
mtanyer
436 Aufrufe, 5 Antworten
Toposolid question
Dear all,
I am trying to create topography (toposolid) from an imported CAD file which contains the contour lines.
The "Level 1" of the model is indicated with the red line.
Revit creates topography for the above of Level 1. However, below Level 1 no topography is created.
What could be the reason of this?
Many thanks.
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: mtanyer
Not clear what you are saying about the Toposolid. I see a large portion of Toposolid below the Level 1/Red Line in your first screenshot. Isn't that brown coming from the Toposolid?
Nachricht 3 von 6
mtanyer
als Antwort auf: barthbradley
Dear barthbradley,
Yes the land is created correctly as a toposolid but I wonder why I cannot see the contour lines below Level1 as in the upper parts. Maybe I misinterpret something.
Nachricht 4 von 6
Nachricht 5 von 6
handjonathan
Hi @mtanyer
Thanks a lot for posting your question to the forums!   Has the solution suggested by @barthbradley helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
Nachricht 6 von 6
mtanyer
Thank you barthbradley.
