Toposolid Not Cutting
3 ANTWORTEN 3
Nachricht 1 von 4
harry_kealy
759 Aufrufe, 3 Antworten
Hi, we're trying to use Revit 2024/ toposolids for a new project but is quickly becoming unusable as the toposolid will not cut in section. It seems very inconsistent and occasionally will cut, but at other times wont. The topo was made by import, and then split at the boundary line.
Is there a fix for this?
Beschriftungen (3)
3 ANTWORTEN 3
Nachricht 2 von 4
ennujozlagam
als Antwort auf: harry_kealy
https://revitpure.com/blog/toposolid
Nachricht 3 von 4
harry_kealy
Sorry to be clear, the issue is not to do with visibility graphics or the process on how to cut the geometry, its an observation of possibly a bug where toposolids that have been split off from another do not cut when shown in a section view and appear as in elevation.
My only workaround so far has been to not split the topography at all and instead just void out with a mass. And even that is finicky on where it starts and stops the void from...never seems to like being exactly on the boundary line/where defining points occur.
Nachricht 4 von 4
rnorrish
Topo surface wasn't perfect but so much easier to work with. it cut Floors, Footings, basic hosted items automatically.
I can't evem model a tilt panel with a gap to the slab and have the toposolid cut correctly without serious workarounds. It's junk.
