I have created a Toposolid using "create from import CAD contour layout." I have also created many voids in this. Now, the CAD layout has been revised. How can I update this Toposolid according to the revised CAD layout without disturbing the voids in the Toposolids?
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | Especialista BIM
Autodesk Certified Professional
Hard to suggest something without more intimate knowledge of your specific modeling. If the updated topo doesn't affect the areas that have the voids in them, then maybe the voids could be salvaged by splitting the topo around their locations, and then just updating the surrounding topo.
https://help.autodesk.com/view/RVT/2023/ENU/?guid=GUID-FA54FCAB-DCAE-43EA-A9E0-FA89D1DA0351
the concern is that if I manually update topo solid the same void, it's sometimes not cut properly.
