Good morning, everyone,
I have inserted an AutoCad and I would like to make a topography using the contour lines of the DWG. However, when I apply toposolid it ignores part of the DWG, I've tried to see if there was a break in the DWG or something else and nothing... everything is normal. Can you help me?
Thank you!
those look like 2D lines from here. Topo can only be created from 3D linework.
Hello thanks for your help.
All 3D Lines...
How can I send you a print ?
Can you show the Properties for the selected elements? Or better yet, just post the DWG here.
what is brad's suggestion? I've also made another smaller toposolid.
The question is whether you can combine the two toposolids so that there are no errors in the quantity tables, or another problems...
Thanks for your help
brad's suggestion is to model the missing piece.
just checked the cut and fill tables. seems to work just fine
they work with two different solids, does anyone know how to put them together? not only for the shedules but also for the graphical aspect. I'm sorry I can't understand what's happening with the dwg... because this could happen in very problematic regions in the future. I've tried it in revit 25 and exactly the same thing happens...
so, i'm having no problem when I create the topography from a CSV file
Thanks for your help, but I have a question.
how can i make sure that the terrain is georeferenced? at the moment i have made the toposolid in both ways and it seems that what was generated through the csv is mirrored. See the print plz.
i'm not having this issue. have u i checked ur orientation settings?
