TopoSolid- Graphics
5 ANTWORTEN 5
Nachricht 1 von 6
jsandsSG3RZ
225 Aufrufe, 5 Antworten
TopoSolid- Graphics
See photo for reference. We have a walkout basement, I have to set the toposolid at the lowest grade as it will not allow me to bring the surface down if I set it at the top grade. But now I have a line that runs through(below the garage) and the hatch changes color above it. I can't adjust either.
The thickness of the toposolid I'm using is 20' and the elevation change is only 9' so I don't understand why it won't let me push down into the toposolid if I use the top grade as the starting point. Which would remove the line all together.
What to I do to get either option to work?
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: jsandsSG3RZ
Is it an override coming from the View Phase Filter?  Show Complete correct?
Nachricht 3 von 6
jsandsSG3RZ
als Antwort auf: barthbradley
It's all "new construction".
Nachricht 4 von 6
So, let's see if I'm reading you right.  You are talking about the difference in the cut patterns appearances; right? One appears lighter than the other.   Almost like it's half-toned.
Nachricht 5 von 6
jsandsSG3RZ
Yes, and why there's a line.
Nachricht 6 von 6
Post your file.
