Toposolid floor plan cut is gray
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
leov13gauer
345 Aufrufe, 1 Antwort
How do I change color and pattern on a toposolid at the part where it cuts from the floor plan view (which would be underground)? As of right now it's this gray color as you can see in the pic. I knew how to do this on normal topography, but I can't figure out on toposolids
1 ANTWORT 1
Nachricht 2 von 2
blank...
als Antwort auf: leov13gauer
Edit type - edit structure - edit the material. Just like floors.
