Toposolid flattening when I split it from one toposolid into 2
Hi
Has anyone had this issue with toposolids in Revit 2024?
I'm getting very frustrated!
Issue is with toposolid (revit 2024) I have single toposolid that I want to turn into two toposolids.
One toposolid around the outside and one toposolid internally that I'm going to use the graded region tool on to create a flat platform.
The whole reason I'm creating this second toposolid is that I don't want the outside surrounding toposolid contours to change. I want to use the new internal toposolid to grade so that I have a perfectly flat platform that both cuts and fills the sloped site.
When I split the single toposolid into two the outside toposolid displays an error message about slabs? and flattens the surrounding toposolid to AHD level (0.00) which the level the toposolid is associated with. Why can't I keep the original contour lines on both toposolids?
