Hello, so i recently upgraded to revit 25 and have been using the toposolid excavate function but it seems like when i excavate with a few slabs the toposolid disappears from one of the floor plan views i created , i had also created a few plan regions in this particular view, please advice =(
Hello
Make sure your main plan view range is capturing the topography level.
graphics should affect on only those region where "Plan regions" are created...
check plan region also capturing the topo level...
Use
Help | Toposolid: Excavate and Remove Excavation | Autodesk
floor used for cutting the toposolid.
Here's a cheat-sheet you can reference when you can't see/find something in a View. I'm sure one of these 33 will apply:
Missing Something in a Revit View? 33 Steps to Find Stuff | Ideate Inc
