Toposolid Cut with Linked Models
4 ANTWORTEN 4
Nachricht 1 von 5
tyler_oneilF6KAD
1645 Aufrufe, 4 Antworten
Often when a project has multiple buildings on one site, I'll have each individual building in its own project and link each project to a main file with the site topo on it. From my knowledge there's no way to cut objects using linked models so is there a workaround to cut a toposolid from a linked model? For example, the linked model of the building has a slab on grade foundation and we want to cut the toposolid site model using that foundation's footings in the linked model.
4 ANTWORTEN 4
Nachricht 2 von 5
JADAstudio
als Antwort auf: tyler_oneilF6KAD
Would using Copy/Monitor to create monitored copies of the relevant foundation walls and/or floors work? I just did a quick test and it looks like it might.
Nachricht 3 von 5
abel
als Antwort auf: JADAstudio
Interesting idea.
Sadly it doesn't work with footings. And when there are many elements it becomes really tedious since, as far as I've experienced, one cannot select multiple elements at once.
Nachricht 4 von 5
bkirk5DP9K
Was there ever a solution to this situation? I am running into the same issue with a linked structural model and the toposolid.
Nachricht 5 von 5
alan.hamiltonGD8UP
Yes having the same issues, I have 35 buildings on a site all as referenced files with differing foundations, same issue, what is the best work around for this?
