Toposolid 10000 vertex number limit?
3 ANTWORTEN 3
Nachricht 1 von 4
Lorenzo.Taccini.STA
441 Aufrufe, 3 Antworten
Anybody experimented a limit in toposolid vertex number?
If I link a Civil 3D toposurface with over 10k triangles everything shows fine. If I convert it to Toposolid or link a toposolid, vertex number gets automatically cut to 10k, missing some points here and there, resulting in a poor fidelity to the original one.
Any hint?
Tags (1)
3 ANTWORTEN 3
Nachricht 2 von 4
Where did you get this information about the 10k limit?
This one has over 60,000 vertices:
Nachricht 3 von 4
Just for the record here; that toposolid has over 20,000 "triangles". Each triangle has 3 vertices, but obviously the triangles share vertices, so there aren't 60,000 individual vertices.  I have no idea how many vertices (e.g. points) make up that toposolid. Maybe it's under 10,000. Maybe it's over 10,000. All's I know is that I'm using only a fraction of the 5+ million square feet. Maybe that's the solution for you.  A smaller "portion". :zwinkerndes_Gesicht:
Nachricht 4 von 4
ct_studio
als Antwort auf: barthbradley
Did you ever attempt to cut/join to this? I am wondering if you experienced as long of wait time for these commands to process as I did (also 60k points). Typically between 30 minutes to 45 for a cut or join.
EDIT - just saw your post below, so the comparison is not applicable. But still interested to know.
