Hi , I tried to make a topography by using absolute elevation ,but different surfaces which is created by putting the points to different level are in the same level. They also are each separated surface. I cannot understand what is the source of this issue. Can you help me?
You created 2 surfaces...you just need One (1) Toposurface and you enter the values for different point as shown below
