Topography visibility in plan view
15 ANTWORTEN 15
Nachricht 1 von 16
posidrive
2658 Aufrufe, 15 Antworten
Hi I have this view in 3D and I want to be able to see the toposurface in plan but nothing shows. Topography is ticked in Visibility/Graphics, View range Top and Bottom and View depth plane are set to unlimited, nothing is Hidden. Any ideas? Thanks.
Beschriftungen (3)
15 ANTWORTEN 15
Nachricht 2 von 16
hmunsell
als Antwort auf: posidrive
basic question.... is the Topography category turned on in the Plan view Visibility/Graphics Overrides?
Howard Munsell
Nachricht 3 von 16
Check these values and lower the Start if needs be.
Nachricht 4 von 16
other possibilities:
-Hidden in View. Reveal Hidden Elements (light bulb icon).
-Toposurface is not within the "sweet" spot of the View's "Cut Plane". Raise the Plan View "Cut Plane".
-Large Plan Region in Plan View is obscuring the Toposurface.  Remove Plan Region.
Nachricht 5 von 16
posidrive
als Antwort auf: hmunsell
Hi, yes this is checked
Nachricht 6 von 16
posidrive
als Antwort auf: ToanDN
Hi, start is set at 0. I tried lowering it to minus figures with no effect.
Nachricht 7 von 16
hmunsell
there are quite a few things it could be. Can you upload the model with the surface for us to look at?
  • are you using Worksets, could it be on a work set that is turned off in the Plan view
  • have you picked Reveal Hidden (light bulb in the bottom left of the view) to see if it is hidden in the plan view
Howard Munsell
Nachricht 8 von 16
posidrive
Hi, I have attached the model.
As you can see it is simply a dwg survey with the toposurface created from the import.
Nachricht 9 von 16
hmunsell
thanks for uploading the file. i don't seem to be having any issue viewing the site on my PC.  it seems to be viewing fine in Level 1 when i open it.
  • check your running the latest 2020 release?
  • check your Hardware Acceleration setting?
  • update your video driver?
Howard Munsell
Nachricht 10 von 16
Nachricht 11 von 16
@posidrive: I'm not clear why you have your Project set up in such a manner, but if I may make a suggestion -- move the Survey Point AND Toposurface down 217000.
Nachricht 12 von 16
nmarcelis
als Antwort auf: barthbradley
@barthbradley @posidrive
coordinates in revit takes effort to master
I always refer to aubin AU course The revit theory of relativity: understanding shared coordinates
Revit Certified Professional Architecture, Structure and MEP.
Nachricht 13 von 16
als Antwort auf: nmarcelis
Point taken. But whether the coordinates are shared or not, it's still odd.  This is about the Survey Point Origin/Marker - and Level 1 -  being 217000mm above the Project Base Point/Internal Origin and Level 0.
Nachricht 14 von 16
I would suggest this setup...
Nachricht 15 von 16
Nachricht 16 von 16
Mohamed-Nassar
check you visibility and graphics is on for topography
check reveal hidden elements
check you created it in the his work set if u work with work sharing file.
If the above reply answers your question; Please mark it with ACCEPT SOLUTION
Mohamed Nassar , ACP, Autodesk Ambassador Gold
BIM Support / Structure Modeler
