Topography view error
2 REPLIES 2
314 Views, 2 Replies
i have my site as a topographic surface and it is seen normal in one of the plan views but gets weird in another when i increase the view depth of the plan view. As in, i need the site to be seen in upper levels but the topography appears somewhat like seen in the attached image.
Can anyone help me to find this error?
1st image shows plan on lower level with the site and the 2nd one has an upper level with the site below
2 REPLIES 2
NeginGHShir
If you do not want to see your site design in your upper views without the topography, you can tick the topography off in your visibility graphic setting and change your view depth to unlimited.
If you find my post is interesting, I will Appreciate it if you give a Kudo.
If it solves your problem, please click Accept Solution.
semko_dm
Hi!
This is triangulation edges.
If you want to see topography without triangulation, you have to untick triangulation edges in "Visibility\Graphic Overrides", for particular view.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Dmitriy Semko.
Dmitriy Semko
BIM-Manager
Blog
Facebook | Telegram | LinkedIn
Tags (1)
